Blew rearend with stock car!!
So its christmas morning and i was bored so i thought id go for a little spin in the camaro..well it didnt go to well..after the first w.o.t(from a roll) i hear a clunk from the rear of the car so i decided to pull over checked but didnt find anything..
i drove the car home it was fine jus makin a weird sound..about 15 minutes later i tryed to pull her out of the garage and it all locked up......i ran out side and oil was all over the driveway! theres a lil whole in the rear end cover!
so what are my options?now
LS1Tech Premium Sponsor
the posi carrier is more than likely the failed part. you can spend upwards of 1000.00 to fix it and upgrade. or... you can spend money wisely on a 12 bolt, S60, or a 9 inch. prices for a good rearend start around 2100.00. if you upgrade the 10 bolt and it breaks again, you already spent the money on the upgrade, now have to spend it again on a good rearend. you end up spending almost 2x as much as a good one to begin with. and the more power mods you make, the worse it will be for the 10 bolt, no matter what you do.
i have the best deal on all of them... my fabricated housing 9 inch, Strange S60, 12 bolt, and Moser rears. pm me for a suggestion on parts and a quote
With a six speed, you're better off with a 9". If you choose 31 spline axles and true trac posi, you wont notice any difference in how the car drives. It'll just be way stronger and dependable. It will work with stock LCA's and panhard bar but I dont know about the torque arm.
If you don't have the money and don't plan to upgrade the car much at all if any you can find used 10 bolts for 300-400 bucks. some of them are even already upgraded. Just make sure it's not junk already before you buy it. But you could still have the same problem... a few months or couple years from the install it may shell out like yours did. so I'd suggest upgrading also, but the options are out there.
If I am comparing apples for apples a 9" canbe built much stronger, has more available parts, wider options for gearing. But it all depends on what your plans are for the car. Let me know if we can help.
Jeff
Jeff
Thanks for clearing it up for me guys I will be goin with the 9 inch now.....because it sounds the most economical and hopefully a bolt in.
...Also ive been seein alot of 9"tru trac with limited slip or locker option??is that the same as a posi?....ill be shopping around for one once i know what model/options i need.. Ill be calling all vendors who replied Thanks
So what are you more mad about the car or the stained driveway? I'd be more mad about the driveway. Anyway if you plan on modding and keeping the car I would upgrade to a 9 inch with an M6. Some A4's get away with it but I wouldn't play games with the M6.
Check my Moser 9 inch prices here, which start at $2,400.00 shipped for a Truetrac with 31 spline axles. http://www.exoticperformanceplus.com....html?item=145
We're only located one hour away from Moser Engineering. Bob
haha I think I was equally relaxed about the car crappin out and the driveway gettin some battle scars...the whole thing caught me off guard because I expected only cars pushin high hp or runnin slicks would have this problem....gm shoulda recalled this rearend in my opinion...but no point complaining jus time to upgrade
Jeff
