Need suggestions on gears?
Im going to do a gear swap this spring and from the research that i have done i would go with gm oem's first but if you want to go with and after market gear go with motive . Talk to jeff at jaws about it he will get you set up ,thats were i am going......not that ,that means much ..
Here are the parts I carry for the 10 bolt rear. Bob
http://www.exoticperformanceplus.com...html?item=1008
Motive 10 bolt gears.
http://www.exoticperformanceplus.com...html?item=1009
10 bolt overhaul kit.
http://www.exoticperformanceplus.com...html?item=1193
10 bolt mini spool.
http://www.exoticperformanceplus.com....html?item=510
Rear end support cover.
http://www.exoticperformanceplus.com...html?item=1126
ARP stock replacement wheel studs.
http://www.exoticperformanceplus.com...html?item=1341
Moser 10 bolt axles.
http://www.exoticperformanceplus.com....html?item=162
Lower control arm relocation brackets.
10 bolt mini spool.
