Leaking TA cover
Old 02-01-2008, 01:55 AM
Benny Blanco's Avatar
Default Leaking TA cover
Is it hard to fix the Leak on a TA cover on a 2002 ss camaro. I never did this before and I wanted to know if its possible to do this in my garage and what gasket or silicon to use and gear oil ???? Please Help Its leaking alot now and i need it fixed asap and i dont have much cash for a shop to do it....thanks BB
Old 02-01-2008, 11:16 AM
wrd1972's Avatar
Pice of cake.
Pull the cover, let it drain, clean the surface, install new gasket.
Old 02-01-2008, 11:36 AM
2001NBMZ28's Avatar
There's a write up w/pics at installuniversity.com
Old 02-05-2008, 11:33 PM
Default ?????
Ok I just did the job but I used High temp RTV silicon gasket sealer. I sure hope this works I hope I wasnt suppose to use a gasket????.....BB
Old 02-05-2008, 11:37 PM
Jawsgear's Avatar
Gasket is over rated. We always use silicone. Some of the cheaper gaskets out there will leak.
Jeff
Old 02-05-2008, 11:38 PM
getusumws6's Avatar
did you mean rtv? for gear oil 75w-90 w/ limited slip gear oil additive..4oz i'm assuming its the stock 10bolt.
Old 02-05-2008, 11:40 PM
Yeah my bad RTV hahahahha....Its been a long day....BB
Old 02-05-2008, 11:41 PM
staringback05's Avatar
mine also leaks...ive replaced the gasket and rtv'd it...think its just the top hole releasing fluid
Old 02-05-2008, 11:43 PM
Yeah exactly hight temp RTV with Amz oil 75w 90 stock 10 auburn diff.....BB
