Waste of money 3.73 10 bolt?
I was planning on putting a 3.73 ring and pinion in my stock 7.5" 10 bolt. After reading so many posts about them, I'm thinking about saving for FORD 9". My car will mostly be a DD, with occasional trips to dragstrip. What should I do? Is it a waste of money to spend $700.00 on ring and pinion in 10 bolt?
The 7.5"s are weak but not as weak as alot of people make them out to be.It has ALOT to do with how well it was setup as to how long they well last.
If your car is a dd bolt on car not putting a whole lot of power down then Id say just hang with a 10 bolt with some 3.73's
If you have something putting a little more donkies to the ground and your car leaves like superman kicked the back bumper then Id say go for a 12 bolt
why would it be $700?
if it is your dd i would go ahead and throw a set of gears in there. I dont mind spending a little money on my 10 bolt just for the fun factor. BUT just know that it WILL break if you go dumping the clutch on some sticky tires. Now i would NEVER dump $700 into a 10 bolt. You are almost halfways to a 12 bolt, S60, or 9". But a set of gears installed shouldnt run you more than $400. If you do it yourself and know what your doing you could install gears, new bearings and seals and possibly a girdle for $400.
My old 10bolt w/4.10s had many many passes on a stock convertor...footbraking...and a handfull with the convertor. Held just fine 3k+ launchs...although was a little noisy towards the end before I put the 12bolt in
Either way 700$ is WAY too much for ring and pinion...should be able to find them alot cheaper than that.
Jeff
$700 is outrageous. No I would not spend that for a ring and pinion.
If you have a shop with a better price though, then yes I would do 3.73's in a ten bolt as long as you are realistic about the potential consequences. Especially if it's an auto, it should be ok for a while.
I installed 3.73s into our 93 manual formula (was 500hp blown, now n/a) and they've held up to drag strip passes and driving for 2 years now. Not saying that is the norm, though.
I LOVE my 3.73 gears! You can do it for under $250 including all parts. I wasn't about to do them myself so I had a friend "help" me for $150. I would much rather spend $400 on a daily driver than $2500+ for what may be overkill.
Just my two pennies.
