Crush Sleeve
Old 02-15-2008, 04:21 PM
Bruser's LS1's Avatar
Default Crush Sleeve
How much torque is needed to make sure I have this tighten down right? I am installing a complete diff in my car that has the gears already set. I plan is to just yank to old diff out and just put the new one in.
Old 02-15-2008, 04:36 PM
1redta's Avatar
Default re
we tightened mine to ~20 inch pounds rotating the nut on the pinion
Old 02-15-2008, 07:40 PM
DaddySS's Avatar
The right tightening is measured by the "preload" on the pinion. 20 inch lbs is about right I think, just don't overtighten because you can't back it off, it's a use once item, so take your time and tighten slowly.
