how can i figure out what gears i have?
I thought i had the stock gearing for a Z28 with a 6 spd. i bought my car used last fall, and the car is pretty much stock. only lid and catback when i bought it, but after talking to people at the track, they said i must have differnt gearing cuz at the end of the quarter i have to shift into 5th. if i leave it in 4th ill bounce off the rev limiter before i cross the line. they had f-bodies as well and they were shifting into 4ht at th end of the track...any help to figure this out would be awesome. thanks
i have 3.73s in my 98 trans am and you can really tell it is way diffrent then stock can you tell the diffrence and just dont know what gears they are or can you not tell the diffrence?
well this is my first ls1 car, so i honeslty dont have anything to compare it to except with what others have said they were running. I havent made any gear swaps. basically im trying to figure out if the gears in my car are the stock ones, or if they were swapped out at some point. and if they were swapped, what are they?
I never ran out gear with my stock gear (3.42) at the track intill I put my 4.10 in. now I have to shift to 5th right before the traps..The number of teeth on the ring gear divided by the number of teeth on the pinion (eg: 41/11 = 3.73) equals the gear ratio..
Well as far as cruising goes with my old 3.42s i would do 90 at 2k in sixth and now at 2k in sixth im doin 74
punch in some different rear end gears to see what you run
http://www.f-body.org/gears/
