HELP!! car is whining
Old 03-14-2008, 07:01 PM
MuscleCarZ28's Avatar
Default HELP!! car is whining
About 2 weeks ago my car started whining on the freeway. If i hit the gas slightly more it whines more. I changed the rear diff. fluid today and it didn't go away.
Could this whine be the drive shaft or tranny? sounds like its coming from the back. what should i check to find the problem? any help would be appreciated. thanks in advance. Dan
Oh the whine is not super super loud, but started out of no where.
I took it to the track the other day and nothing broke, but sounded like it got louder so now i want to solve this problem before something brakes on me.
Old 03-14-2008, 07:25 PM
alamantia's Avatar
whine on acceleration or decel?
Old 03-14-2008, 07:44 PM
acceleration
Old 03-14-2008, 08:15 PM
alamantia's Avatar
http://www.differentials.com/diagnose.html
Old 03-15-2008, 02:27 AM
Originally Posted by alamantia
thanks for the link! very helpful.
this fits my how my car sounds: A howl or whine during acceleration over a small or large speed range is usually caused by worn ring
how much does it cost to change a worn ring?
Old 03-15-2008, 07:42 AM
alamantia's Avatar
Motive or AAM gear set around $150
Fresh Bearings, lube, crush collar, axle seals, pinion seals, gasket (install kit) Around $100
Labor around $150
I just got back from San Fran thursday, first time I have ever been to CA, I saw lots of nice cars out that way
Old 03-15-2008, 12:49 PM
is it ok to drive my car like this? based on what i have read its a worn out ring and pinion and/or possibly a bearing. does this mean its going to fail soon or just means it needs to be changed?
thanks for the help
Old 03-15-2008, 04:26 PM
alamantia's Avatar
they all whine slightly at some point, you can remove the caps, pry out the carrier and inspect the carrier bearings and their races for score marks or pits. Just dont lose track of the shims and reinstall the carrier with the sims in EXACT SAME locations they came out. Its most likely a carrier bearing, if it is just bring the whole carrier to a parts store and have um pull off the old bearings and press on new ones.
Old 03-15-2008, 06:02 PM
thanks alamantia for your help.
Old 09-05-2008, 02:53 PM
5301113's Avatar
Thanks alamantia i have the pinon bearings problems after read this and alot of other forums I know for sure my problems
