What gears do I have?
Old 03-20-2008, 06:04 PM
HoLLo's Avatar
Default What gears do I have?
What gears are these? Can you tell?
6th gear on the highway
Old 03-20-2008, 06:35 PM
MattIROC's Avatar
3.42's to me
Old 03-20-2008, 07:10 PM
HoLLo's Avatar
I was looking at a pic of a LS1 on Fquick, doing 1600RPMS at 60mph, with 4.10s
Old 03-20-2008, 08:15 PM
MattIROC's Avatar
70 should be 2k in 6th with 4.10's. 80 at 2200 rpm.
Old 03-20-2008, 08:17 PM
jpeach's Avatar
Pull the plate and count the teeth...
Old 03-20-2008, 08:21 PM
Internet Mechanic
BlackScreaminMachine's Avatar
IF the tach is accurate and assuming 25.6" tall tire, its a 3.90.
Old 03-21-2008, 04:40 AM
LS1>girlfriend's Avatar
if you give us your tire size xxx/xx/xx we can tell you assuming your tach is dead accurate....which it probably isnt.
Old 03-21-2008, 09:20 AM
HoLLo's Avatar
27540ZR17 all around
Old 03-21-2008, 09:56 AM
Internet Mechanic
I re ran the calculator, even with it being a 17, the side wall shrinks and the rim expands and the Overal Diameter is the same, on 3.90's its dead on @ 1800.
ASSUMING maybe a slipping clutch or a off tach it can be 3.42's due to it showing 1550/1600 is 70 mph.
Old 03-21-2008, 02:23 PM
im not encouraging you to speed, but if you know what rpm and gear your in at...say 120 mph will those same tires/wheels it will be more accurate.
