rear end goin?
Old 03-23-2008, 01:54 PM
goinfast's Avatar
Default rear end goin?
with the back tires off the ground, when i move the tire theres a half inch of play before the pinion moves. after a half hour of driving when i take off it klunks from the rear of the car and when idling along in traffic it klunks as it chugs. i thought maybe the universal but it seems to be good.
Old 03-23-2008, 03:02 PM
ski23's Avatar
pull the rearend cover and check the posi. I just broke mine at the dragstrip and it would clunk under any load. pulled the posi out and sure enough had several teeth torn off the spider gears
Old 03-23-2008, 03:23 PM
goinfast's Avatar
i checked that and it looked good, it just seems theres alot of play between the ring and pinion gear. the car has the stock gears with 190000kms on it.
