wont hold oil
Old 03-24-2008, 06:42 PM
BreaK's Avatar
Default wont hold oil
Ok so i replaced the diff cover this week. I drove it for about an hour to see if it held and it did fine. Now i go outside after it sat for about a day and all the gear oil is in my garage. what should I do? I put rtv all the way around the gasket and torqued the bolts down to 25 ft/lbs.
Old 03-24-2008, 06:44 PM
GregWS6&z28's Avatar
if the diff cover was all you changed them you must have missed something. was it leaking before?
Old 03-24-2008, 06:59 PM
fasttimes1's Avatar
What diff cover? TA? Correct bolt length? Forget washers?
Old 03-24-2008, 07:03 PM
linegtdt52's Avatar
dont use the gasket and only use rtv I used hondabond and that stuff is the ****
Old 03-24-2008, 07:31 PM
BreaK's Avatar
10 bolt on a TA. The diff cover was all I changed and I used the correct bolts and washers sent from mac.
It was leaking before but I assumed it was because the diff cover was bent
Old 03-24-2008, 08:46 PM
wrd1972's Avatar
Use RTV.
Old 03-25-2008, 01:05 AM
BreaK's Avatar
I did use it....
Old 03-25-2008, 02:18 AM
FrankSS's Avatar
use only rtv and no cork or whatever gasket....
Old 03-25-2008, 02:49 AM
BLACK2001SS's Avatar
Did you cleen up the surfaces good? I like to hit stuff like that with a die grinder with scrubby pads.
Old 03-25-2008, 01:35 PM
BreaK's Avatar
I used a scraper and 1200 grit sandpaper...
