94-97 10 bolt
Old 03-26-2008, 06:38 AM
Dean95z28's Avatar
Default 94-97 10 bolt
I picked one up for 100 bucks to put in my 99 TA becouse its trashed. will all my brakes fit on that axle without any special stuff?
Old 03-26-2008, 07:40 AM
alamantia's Avatar
is your car a 3 channel or 4?
is the rear a 3 channel or 4?
Old 03-26-2008, 09:14 AM
Dean95z28's Avatar
I don't know honestly. If that has to do with the ABS It doesn't matter, becouse I am taking it off anyways.
Old 03-26-2008, 09:22 AM
BIG_MIKE2005's Avatar
For some reason I was thinking that some of the mounting points are different for 98-02 f-body cars & the older housing won't directly bolt in. But I could be wrong.
Old 03-27-2008, 11:28 AM
connexion2005's Avatar
As far as I know they actually should fit. I had a buddy swap and lt1 rear in his 02 z28 without issues at all...
Old 03-27-2008, 11:53 AM
LS1powerhouse02's Avatar
I am 99% sure you will need to pull the axles and swap the backing plates from your LS1 rearend to the LT1 rearend. Otherwise your brakes wont bolt up to the LT1 backing plates.
I am the friend connexion is talking about. I am pretty sure I swapped them out although it was a while back. Just compare them side to side and see if the backing plates are the same bolt pattern or not. Other than that as long as they are both the same channel it will bolt right in.
Brent
Old 03-27-2008, 01:10 PM
Maybe thats what it was. Just need to swap the backing plates over.
