Help me pick Rear end
Need help picking the right rear end for my turbo T/A. Here is the low down. Forged 347, ST80 turbo, M6. What rear? I want thinking a 9" or a S60. This is a street car and will see some track use but not much. 800whp. Please give me the options for the rear end too. True track, Locker etc. Thanks!!e
how much power are you puting down? I was told that the true track would not hold my power level and to get a Detroit locker, but they are not street friendly. I am leaning twards the 9, but what internals
Go 9'' and 3.50's for a M6 or even 3.25's if you want. I am going 3.00 or 3.25's for my auto. With an auto its a lil less hard on the rear and the trutrac has proven to stand up to allot, even at the track. I am talking 1000fwhp and 1.4 60 ft's. I am going with a trutrac myself b/c I don't want it chewing up tires, my abs light on, the constant drag around corners, etc. If you are worried get the spool and not the locker in my opinion. I was in this debate hevily, jsut go to the rear section and do a search. Ton's of info and even some fairly recent one's that you'll see that I was in ***** deep.
You're in a crossroad where the Truetrac should hold it, but on a sticky track and if you start cutting 1.30 60 ft times, you could possibly break it. On the street I wouldn't see any problems with it at all. If it were me I would go with a spool. Spools work quite well for weekend driven cars, and commuting if on rural roads and highways where you don't spend a lot of time turning tight corners. A spool is also lighter, has less reciprocating weight and cost less.
http://www.exoticperformanceplus.com....html?item=148
Moser with a spool.
http://www.exoticperformanceplus.com....html?item=145
Moser with a Truetrac
Moser rears are shipped just two days after the order is received! Bob
Moser with a spool.
the 9 inch is almost bullet proof and it takes less power to drive plus you can change gears much easier but it is just a matter of opinion im not saying that the s60 is a bad rear its just as good as the 9 inch
not true. takes the most power to spin but we are only talking an extra 2 to 3 % not much.
