Narrowed Moser 9 inch - Wheel back Space
Thinking about ordering a moser 9 inch narrowed 2.5 on each side,
i like the look of the deep dish wheel vs the stock look,
my question is if go with the above set up will a 8 inch
wheel with 4.0 back space work ok using a 275/60/15, will i have any
clearance issues? (98 Camaro)
any input would be appreciated!!
THANKS!!!
THANKS!!!
If you thinking of something like a Weld wheel. Usually on a stock size rear guys use
15'' x 10'' 7.5'' b.s.
15'' x 8'' 5.5'' b.s.
So if you narrow your rear by 2.5'' and want an 8'' wheel I would think a 3'' b.s. would put you in the stock location.
Main thing to watch is the distance to the Lower Control Arms
I recently had my SS Minitubbed and narrowed the rearend 3" per side.
I went with the 15x10 wheel with a 5.5" B.S. due to hitting the LCA's.
AND,......... I still had to use Offset LCA's.
However, the Offset looks Killer
It tucks up the 325/50/15 M/T DR's on 15x 10's rather nicely.
