Motive 4.10. where does it say in pinion what shim to start with?
Old 04-16-2008, 04:49 PM
mvvette97's Avatar
Default Motive 4.10. where does it say in pinion what shim to start with?
I was told or have read that motive gears will say on the pinion what shim they recommend. It has some numbers but none that would be a shim size. Also are these gears really made in Korea? It says it on the box but I thought Motive was american made
Old 04-16-2008, 04:54 PM
mvvette97's Avatar
ok the pinion hasengraved on it 3.779 and 11-119
Old 04-16-2008, 05:59 PM
ss1
ss1's Avatar
It wont tell you which shim to use, because every rear end is a little different. You need to set the pinion depth to 3.779". What you need to do is measure from the centerline of the ring gear/carrier to the face of the pinion. Start with no shims and get a measurement, then add shims accordingly.
Old 04-16-2008, 06:32 PM
mvvette97's Avatar
oh ok. I'm having a guy help me that has set up alot of rears so he should know what to do then.
Old 04-16-2008, 06:35 PM
ss1
ss1's Avatar
Cool, I read you other post about the gears that are in the car right now. Good luck, I hope the new ones take care of the problem.
Old 04-16-2008, 06:38 PM
mvvette97's Avatar
yea me too. I'm about tired of the whine.. Do you know anything about why my Motive box says made in Korea? I thought Motive was US made.
Old 04-16-2008, 08:25 PM
alamantia's Avatar
reuse the old sime and get AAM gears
