C-Clip Problems....
C-Clip Problems....
Ok, so I started in on the 9 inch swap tonight, got the calibers off, drained the 10 bolt, took the pin out thats in the middle of the carrier....
Go to push the Axel's in to remove the C-Clips...well C-clips are in pieces! and wont come out!!!! Its like the Axel's need to come in another half an inch or so....Looks like my ABS rings are stopping it....
WHAT AM I DOING WRONG! Need help ASAP!
Thanks guys in advance!
feel sure you have 4 channel (tc/abs)you must loosen or remove the tc sensor from both backing plates if you look you will see the small pin ( pickup pin) is sticking out and pressing against the reluctor ring, then the axles will come in about 1/4 in and the c clips will fall out
good luck, Johnny
good luck, Johnny
