Pieceing together a 9" Help?
Ok, sense i know i can't afford a complete rear, i'm considering getting the 9" hoseing from Moser for 610.00, then pieceing it together over time, my only delemma is my ABS system, mine has the sensor on the 3rd. member houseing, is there anyone that can modify "driil/tap" for the sensor on a standard style 9" 3rd. member, is it hard to do? Please help
no sure ,I think you can order the moser housing pre drill for 3 channel, ask your supplier, go to moser,s site and look.
chk with our sponsers.
good luck,Johnny
ps sponser EPC as well as some other sell
"ABS (3 channel) or ABS/TCS (4 channel" houseing
good luck,Johnny
The Moser center section that is designed for the ABS is specially modified and has a reluctor ring installed in it. Your are not going to be able to use a non ABS 3rd member and modify it for the ABS, at least not easily. Your best bet is to buy the Moser housing and axle package for $1000.00 shipped at this link, and forget about the ABS. http://www.exoticperformanceplus.com...html?item=1116
If you don't hook the ABS up in the rear, the front ABS won't work either, and you'll be back to old school brakes. I prefer non ABS brakes anyway, but that is just my personal preference. Bob
