Going with 3.73's, What brand for my 10 bolt?
Im for sure going for 3.73's in my rear. But my question is what brand should i get. The shop that is going to do it for me generally uses and has had good luck with Yukon gears. Anyone have them? Im just looking for something that is quiet, with no whine at all. What brands should i choose from? Thanks
Good luck with that..You will have whine no matter what..But some are worse..Richmond whines bad..I just got Motive's in mine.3:73's. I put on about 400 mi..they still whine..Its going back to the shop tomorrow for a follow up..They will adjust them and change the lube..Hopefully that will take care of it..Or its going back again..If you want quiet,leave the stock gears in..
If the gears are set up "right", you shouldn't be getting any noise, i went with the Yukon's behind my BB mopar running high 10s with 1.5 60ft. times & over 200 passes, they were like new, i say for the price they are a good gear, nice & sturdy, this was in an 8.3/4, don't know how well the 10 bolt 7.5 gear will do though.
