10 bolt posi question... - LS1TECH
Thread Tools Search this Thread
Old 05-04-2008, 12:19 AM   #1
Default 10 bolt posi question...
I have a 98 Formula with 2.73s. The posi isnt working and I want to go to a steeper gear. I found a 3.42 rear end for $50. But it has a bad spider gear. It is out of a 2000 ss.
What kind of posi do I have in my 98 Firebird? Does my 2.73 rear end have the same spider gears, or is it a different type of posi?
Thanks for the help.
JGoodin86 is offline   Reply With Quote
Old 05-04-2008, 10:08 PM   #2
Ok, i am pretty sure my 98 has a auburn. So if the 3.42 rear end has spider gears, it has to be an auburn also.
Will spider gears out of a 2 series fit in a 3 series carrier?????
Old 05-04-2008, 10:20 PM   #3
JimsWS6's Avatar
I thought I've read before the newer cars had a different limited slip. I'm not too sure, you'll have to wait for a more knowledgeable person to chime in
JimsWS6 is offline   Reply With Quote
Old 05-04-2008, 10:33 PM   #4
There are different...I found this out the other day when I removed the covers. 98 vs 99 and up.
ta_06374 is offline   Reply With Quote
Old 05-04-2008, 10:37 PM   #5
99+ is Eaton
FirstLSx is offline   Reply With Quote
Old 05-05-2008, 04:52 PM   #6
Quote:
Originally Posted by FirstLSx View Post
99+ is Eaton
Are you sure????
Old 05-05-2008, 04:58 PM   #7
This guy was selling an auburn rear out of a 2000 ss, so I dont think that is correct. I dont think any 98+ f bodys came with eaton stock.
FS: Rear End, 3.42's, Auburn, 3k mi
They are either auburn friction type, or torsen worm gear type.
Anyone else know...
Old 05-05-2008, 05:08 PM   #8
keliente's Avatar
99+ is Eaton
No it's not.
keliente is offline   Reply With Quote
Old 05-05-2008, 05:22 PM   #9
Anyone else know...
You are correct. The SSes (and Firehawks as well, I believe) were offered from SLP with the option of an Auburn (Pro??) instead of the stock Torsen T2.
'99 and up, Torsen T2 stock.
dailydriver is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
