With 3.23s what RPMs do you turn at 70mph?
Old 05-04-2008, 04:00 PM
Cape T/A's Avatar
Default With 3.23s what RPMs do you turn at 70mph?
I have 02 A4 ws6 that i bought with 16k miles on it. it has the GU5 Code (3.23) but i turn just a little over 2000rpms at 70. Comparing it to several of my friends cars (also A4 4th gen F-bodies) i turn more rpms than them.
so i was curious and jacked the car up and turned had to turn the driveshaft just a little under 3 1/2 turns to get the tires to make one exact revolution. wich to me seems like they would be 3.42 gears. i could be making a mistake somewhere or someone could have swaped the gears out in the car, but i would doubt it being such a low milage car with an older couple being the original owners. or is it possible that the factory could have made a mistake? my speedometer is correct though, so the computer would have to have been corrected for the gear change.
Old 05-04-2008, 04:12 PM
MattIROC's Avatar
I "think" 3.23's at 67 mph is 2k... You may have 3.42's as you said.
Old 05-04-2008, 05:46 PM
Cape T/A's Avatar
hmm..interesting.
Old 05-04-2008, 07:39 PM
Irocem99's Avatar
Not if its a stock WS6.. I had 2:73's and I was right around 2k at 70..It would be more around 2200-2250k with 3:42's I think.. I'm pulling around 2450 with 3:73's. I can't see someone throwing 3:42's in the car with 16k,they would have advertised it I'm sure.
Old 05-04-2008, 07:57 PM
MattIROC's Avatar
All I came up with when searching was this: 3.23's at 75 is 2200ish (22xx to be exact).
Couldn't find anything at 70 mph.
Old 05-04-2008, 08:32 PM
Cape T/A's Avatar
but is that with the converter locked or unlocked, because that makes a difference in the actual number.
i guess what im asking is for someone who knows for a fact that they have 3.23 gears in their car that the next time they take it up to 70mph check out their rpms and see what they get and let me know.
Old 05-04-2008, 08:40 PM
MattIROC's Avatar
converter locked.
Old 05-04-2008, 08:54 PM
LS1Silverado05's Avatar
About 2100 is what I used to turn on 3.23s @ 70.....Keep in mind small variations in tire diameter could make a small difference on the tach...
Old 05-05-2008, 09:40 AM
jmm98LS1's Avatar
When I had the auto and 3.23's I turned 2200rpm @ 70mph.
Old 05-05-2008, 10:05 AM
Automaticfastic's Avatar
I have had ride's with both 3.23's and 3.42's. I know how fast im going at 2k...... With the 3.23's its 67mph for me...... witht the 42's it is 62 mph at 2k. So if your barley over 2k at 70...... its probobly the 3.23's..... But why dont u see how fast your going at 2k rpm instead of 70mph and figure it out that way.............
And no one is going to change from 23's to 42's unless they're not hot rod savvy would be a nice way to say it.......
Old 05-05-2008, 10:12 AM
nor-texLS1's Avatar
ive got 3.23's and turn 2200 at 70....sounds like ur friends have 2.73's
Old 05-05-2008, 01:24 PM
caliswangin916's Avatar
stock 3.23 was 2k at 67 mph for me and the other posts i've seen.
Old 05-05-2008, 02:55 PM
lt1noob's Avatar
i have an lt1 with 3.23s, ill check if i get out cruising any time soon.
Old 05-05-2008, 04:44 PM
Cape T/A's Avatar
well, thanks for the opinions. this answered my question, basicly what im noticing is that with 3.23s everyone is turning 2k from 67-70. so there are some slight variables, that play in.
so it sounds like i have 3.23s. Thanks.
Old 05-05-2008, 04:55 PM
99_ls1_z28's Avatar
Yes you have 3.23's. My auto used to be at 2100rpm @70.
Old 05-05-2008, 08:25 PM
01WS6er's Avatar
mine has 3.23, it turns about 2200 at 70.
Old 05-06-2008, 12:35 PM
nahasapeemapetalon's Avatar
bout 2k -22oo i think.
80 is 2500
Quick Reply: With 3.23s what RPMs do you turn at 70mph?
