Wheel stud question
Wheel stud question
Not sure if this should be in drag tech or here. I need to replace my rear studs. I have ARP 3.25 studs. Do the axles need to be pulled, or is there a way to do it with them in?
Yep, I put in 3.25" ARPs in my 9" with the axle IN. They were the press in's. Take out the TCS sensor, and that's where the studs go through the backing plate at. As for getting them in, I took a good Grade 8 nut, and lubbed up the press in section of the stud. Then, just put the bolt through, and put the nut on it. From there, get an impact gun, and bring the stud the rest of the way in.
Done.
Done.
Be careful if you choose not to pull the axle it can stretch the threads. For the time it takes you to play around with all the mickey mouse stuff it would be easier, safer, and cleaner to just pull the axle shaft out and press them in.
Jeff
Jeff
