synthetic ok in new 9" with detroit tru trac?
I am pretty sure the synthetic is not ok with clutch type ltd slip, but the tru-trac has no clutches and therefor does not require ltd slip additive. Can I fill her up with a synthetic gear oil? Thanks Oh I did a search and some say no do not use synthetic and another said they spoke with detroit and they said it was ok since the tru trac has no clutches??? I'm confused.
Does anyone know the reasoning behind this? I was under the impression you could always swap regular oil of any kind with synthetic? If the Tru Trac has no clutches why can't you use sythetic do they want you to wear out the rear end sooner than later so you have to puchase another just like the factory recommends oil changes at 8000 mile intervals or so with regular oil? So they can make more money in the long run?
The only difference we see when we tear stuff down is NO wear when we use RP. The axle bearings didn't wear out, the silk screen was still on the clutch packs, my motor stayed together during 50 miles of 340* oil temps @ 140 mph (water pump wire broke). Personally, I'll never use dyno oils again in the hot rod except to break things in.
synthetic will not void any warrenty in a locker
https://ls1tech.com/forums/showthrea...812&highlight=
I think the reasoning for the use of conventional oil in the differential as opposed to synthetic is that conventional oil "climbs" up the gears better as they spin.
Has anyone seen that hand cranked display that lucas oil uses in the parts stores to show how there oil climbs the geartrain as it is in motion?
This may be the reason companys don't warranty due to poor gear lube supply.
Correct me if Im off base on this guys.
