View Poll Results: Keep 3.73s or go 3.23s
Keep 3.73s
12
92.31%
Go 3.23s
1
7.69%
Voters: 13. You may not vote on this poll
3.73s to 3.23s need OPINIONS
Well now gas is over 4.00 a gal. thanking about ditching the 3.73s and going to 3.23s
Now what i was going to ask with a 3600 stall still will leave hard with 3.23s right?
Car is a DD highway all the time what do you guys thank!!!! Need opinions wish i had a M6 now
I got 26mpg once doing 70mph on a trip to florida(all highway). My car is a 1999 z28, stock 3.23, stock trans, only mods are catback, lid, and stock 16" wheels. Big, heavy aftermarket wheels can affect your mileage as well.
I usually get between 20-22mpg, driving 80% highway, 15% stop and go, 5% ***** to the wall
you probably wont see much of an improvement with the gearswap, maybe 2mpg on the hwy max. the problem is city driving is still going to suffer. unless the swap is going to be damn near free, i wouldnt do it.
gears won't affect the mileage too much for street driving, you'd be lucky to see 1-2mpg on highway. I did a test at 65mph on highway then 75mph return trip. Used virtually the same amount of gas. With a gear swap, it's basically 3.73-3.23 is barely 300rpm which doesn't do much mileage wise.
The stall really kills mileage unfortunately, you may be able to find a better more efficient stall instead with perhaps an earlier lockup specifically geared to extend gas mileage.
your city mileage might actually go down since the stall will have work harder on take off from a light. Like said before, unless the swap is free, stick with what you got. Are gonna save enough gas to justify the swap?
Thanks For the opinions i am probably keep my 3.73s i kept track and got 260 miles a tank last fill up, not bad at all the crap 2.73s got 280 sometimes but no holeshots! at all
If you already have 3.73's I would keep them. If you get to a point where you are concerned about the price of gas you should get a second car as a beater.
It's so much more enjoyable when your f-body is a weekend only car.
