just got a Moser housing and want to make sure I install the axle seals correctly. Which side of the seal faces toward the third member? One side is solid and painted. The reverse is hollow. Thanks
Great. Thanks. The more I looked at the seal and axle tube, the more I second guessed the direction. I did get directions on bearing orientation and backing plate position.
