TA Performance rear end cover is it worth it?
Location: rochester ny/ cannon air force base, new mexico
1 Post
just wondering if its worth it till i can save up and get a bigger rear end... still got the little 10 bolt in there with a eaton posi locker with 4.10's going to be running 460-470rwhp just wondering if anyone thinks itll hold up for a little while... and ive seen some guys pull wheelies believe it or not with there 10 bolts and slicks! so i would just like some input thanks!
- TA Performance's rear-end covers (girdles) are designed to improve ring and pinion gear life by pre-loading the bearing caps while also adding additional strength to your rear end housing
http://www.exoticperformanceplus.com....html?item=510
This cover and others like it will indeed help, but usually something will still break on the oem 10 bolt. It is a gamble, some last a while, others break pulling out of the garage. Bob
