launching a z28 M6 with drag radials and 4.10 gears but with a 10bolt
Old 05-26-2008, 08:38 PM
Rednaxela's Avatar
Default launching a z28 M6 with drag radials and 4.10 gears but with a 10bolt
thx for info
Old 05-26-2008, 08:50 PM
Sideways240sx's Avatar
4.10s like to destroy 10 bolts. You could shift 1 to 2nd and have it break on a drag radial. Its all just when, not if. that being said ive launched around 4k on 4.10's with et streets on a 10 bolt thats not broke. Im lucky.
Chris
Old 05-26-2008, 10:09 PM
LM97Z's Avatar
Be very careful lol, i've seen them pop on street tires off the line, you can't put any limit on the 10 bolt & 6sp., its just a matter of time before it breaks, don't know when it'll happen, but rest assured IT WILL, your playing with fire useing MTs & 4.10s, put a good rear/shaft under it & give it hell.
Old 05-27-2008, 11:22 AM
Redlinez's Avatar
I never took mine above 3200 on the "launch", which without a doubt isn't launching. More like bogging.
Old 05-27-2008, 12:57 PM
SLP Firehawk's Avatar
i use to launch mine around 3k and the car bogged so much i was getting like 2.0 60ft's i was getting fed up so next time around i waited for the lights to come down and just mashed the gas and let the clutch fly... the front end of the car felt like it was going to take flight i pulled a 1.86 on bdg's with headers only. now i have a cam and 4.10's and i'm alittle worried about launching with my cam 4.10's and new ls7 clutch
Old 05-27-2008, 01:55 PM
Colin91Z's Avatar
I ran consistant 1.79-1.80 60' times with my 4.10 geared 10 bolt.....but it broke about two weeks ago
Surprisingly though, it wasn't the ring and pinion that failed, it was the diff itself. It puked its guts out.
For the record, this was a re-inforced 10 bolt. I had welded the tubes to the center section and also welded added bracing to keep it from distorting under power (which is what leads to broken ring and pinions) Also it had a aluminum girdle and main cap studs too.
Bottom line is if you're on sticky tires with an M6, your 10 bolt's days are numbered. End of story. No matter what gear ratio your running.
Old 05-27-2008, 02:48 PM
ndfrsd6's Avatar
definately be careful i twisted both my axles apart on nittos which suck!!! but that was at the track on a 4000 launch ......i pushed till it broke lol.....
Old 05-27-2008, 03:53 PM
yeah i broke my diff twice already i forgot to mention that
Old 05-27-2008, 03:59 PM
EPP
EPP's Avatar
The 10 bomb is just a waiting Bob
Old 05-27-2008, 04:23 PM
BriancWS6's Avatar
I blew my motive 4.10 geared 10 bolt on the 1-2 shift at the track on Nitto DRs in nov 06. The Torsen posi couldn't take the power and all the teeth on the worm gears shredded off. I got a free replacement from a buddy and put it back together. I haven't been going to the track OR running from a dig since. 1.5 yrs and a little over 9k later and it's holding. I do 2nd gear rolls, and with 615RWTQ, it's still going, whines on decel, but it's still together.
Old 05-27-2008, 04:27 PM
Camaro396's Avatar
Like others said, its not if it will break its when. Its going to happen no matter what. Just depends what day it was built. I know guys who have broken them at 20k miles, and guys who have broken them at 130k miles.
Old 05-27-2008, 04:47 PM
EPP
EPP's Avatar
I remember a guy on here saying he broke his 10 bolt backing out of his garage. lol You just never know when it is going to let loose. This is the rear that I recommend.
http://www.exoticperformanceplus.com....html?item=145 Bob
Quick Reply: launching a z28 M6 with drag radials and 4.10 gears but with a 10bolt
