Bad luck with Eaton Differential
Old 05-30-2008, 04:52 PM
98z8uup's Avatar
Default Bad luck with Eaton Differential
I bought a eaton unit from someone who told me the unit is for a 7.5/7.625 10 bolt. Come to find out it is not. The only thing he told the truth about is that it is a new uint. So will some tell me how can i find out what this unit fits, so I can try to sell it. Its to big to be for a 7.5/7.625, and no I do not have a part #.[ATTACH]Attachment 135073[/ATTACH]
Old 05-31-2008, 05:57 AM
odarabla's Avatar
Measure the ring gear and that should tell you if it's for a 12 bolt, 9", or a Dyna60.
Old 05-31-2008, 07:53 AM
98z8uup's Avatar
I will do that today. Let you know what I come up with.
Old 05-31-2008, 09:40 AM
9000th01ss's Avatar
An "Eaton unit" does not come with a ring gear on it.
Seeing if its for a 10 or 12 bolt is a no brainer, just count the ring gear bolt holes.
Other than that you're going to have to get it in the hands of a very experienced person, or maybe call Eaton, they do have numbers stamped on them.
Or at the very minimum post some detailed pictures.
Old 05-31-2008, 12:24 PM
98z8uup's Avatar
Ok I counted the the bolt holes. Their are ten and the space where the axles go in are 1-1/4. This might be for a [Ford] or a [Mopar]. I will call [Eaton] on monday.
Old 05-31-2008, 01:20 PM
dailydriver's Avatar
Could also be for a GM 8.5" 10 bolt, as in the GN Bufords.
Old 06-02-2008, 09:40 AM
98z8uup's Avatar
I called eaton, and they said it will be hard without looking at it. Maybe I got the wrong guy on the line I will call back later.
Old 06-02-2008, 11:00 AM
odarabla's Avatar
This is what I meant!! Sorry, I was just back asswards!!
Old 06-02-2008, 03:08 PM
98z8uup's Avatar
I did not get time to call back, but if anyone can help me out let me know. I need to try and sell this uint. If i do find out its for a GM i will have it for sale on here for 200.00.
Old 06-03-2008, 04:37 AM
EPP
EPP's Avatar
You need to post pic's. Bob
Old 06-03-2008, 03:27 PM
98z8uup's Avatar
I got back with someone from eaton and they told me the same thing. Its going to be hard to know what its for. So I will take a picture of it, and put it on here as a pick up sale only. Now I will ask 150.00 for it.
Old 06-07-2008, 03:18 PM
98z8uup's Avatar
I just need to sell it now
Old 06-22-2008, 01:57 PM
98z8uup's Avatar
I still need help with this can anyone help me out. Its hard to sell something when you don't know what you are selling.
Old 06-22-2008, 06:48 PM
9000th01ss's Avatar
Count the splines on the side gears. If it's for a factory replacement you can assume these are some that are specific to ten bolts:
30 spline should be mid to late 80's GM truck 8.5
28 spline might be '73 to early 80's GM car 8.5
31 spline should be 8.8 ford truck except ranger
28 spline might be 8.8 ford ranger
It would help if you could get a pic of the inside view of the side gears to see if it's a c-clip type.
Old 06-23-2008, 08:13 AM
98z8uup's Avatar
I will count the splines and try to get a picture of the inside as soon as I can.
Old 06-26-2008, 08:24 AM
98z8uup's Avatar
Thanks for all your help. I got the thing sold.
