Tcc and abs issues with 9 Inch. Help Please!
I just finished my car and got it out, over winter i did a moser 9 inch with 31 spline axels, a detroit tru trac and kept the relucter rings to retain abs and tcc.
Just finished the car last night and the ABS inop light is on and it keeps throwing a traction contol code, When you hit the brakes they pulse like the abs is kicking on, then once the light comes on the brakes are good to go. has anybody ever had issues with the moser relucter wheels? Any Help is greatly appreciated! Thanks
Can anyone else help with this? I seem to be having the same issue. I pulled my sensors, cleaned them, and tested the voltage, they are both showing 4.79V. Am i missing something do i need to re-bleed them?
Oh BTW, these are the codes I am getting:
PCM] P1637 - Generator L-Terminal Circuit (Pending) (History) (Immature)
[PCM] P1639 - 5 Volt Reference 2 Circuit (Old) (History) (Current) (Immature)
[Brake] C0245 - Wheel Speed Sensor Frequency Error (History)
[Brake] C0046 - Brake Pressure Sensor A/B (Current)
[Brake] C0051 - Steering Wheel Position Sensor (Current)
