Cant remove axles!!
Old 06-12-2008, 12:28 AM
Maroguy98's Avatar
Default Cant remove axles!!
Can anyone tell me how to remove the axles on a Moser 12bolt, 33 spline axles. The rear has no abs or traction control, so I know that the sensors aren't in the way by the backing plate. Any input anyone?
Thanks,
-Pat
Old 06-12-2008, 01:22 AM
Revelation Z28's Avatar
did you push them in and remove the C clips if you have them?
Old 06-12-2008, 01:50 AM
9000th01ss's Avatar
How you remove them depends on the differential type/brand.
It either has C clips or not.
With c clips remove the crosspin bolt and pin, brakes, and push the axle in and turn it until you hear the c clip fall out, then pull the axle.
If you have a non c clip type, just remove the four brake backing plate bolts and pull, you don't even have to remove the cover/drain the fluid.
Old 06-12-2008, 04:34 AM
EPP
EPP's Avatar
Thumbs up
Correct, and when you have to pull, sometimes you need to really pull! A rubber mallet is sometimes required to coax the axles out of the center unit. Bob
Old 06-12-2008, 05:24 AM
roy
roy's Avatar
Slide hammer works great too
Old 06-12-2008, 10:38 AM
Maroguy98's Avatar
Thanks guys, I'll give it a shot.
Old 06-12-2008, 11:43 AM
Maroguy98's Avatar
Is there a way to tell if it has C-clips, or is it pretty much a guessing game?
Old 06-13-2008, 09:59 PM
9000th01ss's Avatar
Take the cover off and shine a light at the ends of the axles.
