moser rear end..what gear oil????
Old 06-18-2008, 11:51 AM
silverLSWON's Avatar
Default moser rear end..what gear oil????
i have a moser 9 inch rear end with a 31 spline trac lock posi and i was wonderine what gear oil to use...weight ..brand and if i need pos1 additive. also how many quarts
Old 06-19-2008, 04:32 AM
EPP
EPP's Avatar
If you have a Truetrac then you don't need additive, if it is a center unit that has clutches in it then you will need the additive. Use 80/90 weight or 85/90 weight non synthetic gear lube, we use Napa's brand.
Here are the Moser installation instructions.
http://www.exoticperformanceplus.com...html?item=1263 Bob
Quick Reply: moser rear end..what gear oil????
