Axle repair bearing
Old 06-22-2008, 11:24 PM
9000th01ss's Avatar
Default Axle repair bearing
I just installed a Timken axle repair bearing on one of my camaros because the axle was pitted up. It's a near stock car, drivers side. Do these work ok?
I've used them before in a 8.8 ford rear that was in an S10 with no problems, but it was not a daily driver, and never went on long trips (1000 miles+).
There was a problem here though because it has a torsen diff and the axle wouldn't go in far enough. I had to push it in with a c-clamp clamped to the axle flange and backing plate, it seems this would have shoved the taper on the axle into the seal.
Other than that are these things reliable?
Old 06-23-2008, 02:21 AM
bigfatls6's Avatar
did you pull the rear wheel speed sensors off? If not they were probly keeping your axles from going in far enough to get the c clip out.
Quick Reply: Axle repair bearing
