How do you remove stock u-joint?
Old 06-25-2008, 09:20 PM
Superjoe's Avatar
Default How do you remove stock u-joint?
I guess you have to melt out the two little nylon tabs sticking out? I'm not really sure what to do. Any help would be greatly appreciated.
Old 06-25-2008, 09:55 PM
jmm98LS1's Avatar
I just melt out the plastic by even heating with a propane torch, being careful not to get anything too hot in one spot. Then press the caps out with a vice & sockets. Takes 'bout 15 minutes.
Old 06-25-2008, 10:20 PM
9000th01ss's Avatar
When you heat it with a torch be careful. Sometimes the grease gets hot, builds up pressure and will shoot the cap off with some force. Had that happen a few times.
Old 06-26-2008, 07:25 AM
Superjoe's Avatar
oh, thanks. I'll do it outside then.
