B4C package rear diff question
Old 07-31-2008, 01:04 PM
TurbopigB4C's Avatar
Default B4C package rear diff question
I was looking at Motive Gears website and they list a 4.56 gear for the stock 10 bolt but the carrier cross pin must be modified. It has a note though that for ws6 and ss models they use a torsen type differential that uses a block and paddle that you can't modify the pin. I have a 99 camaro with the B4C package I was wondering if it might have that torsen type since it was a police car. Does anyone know?
http://www.motivegear.com/tech_info/...tructions.html
Old 07-31-2008, 01:27 PM
alamantia's Avatar
when you try to put the thrust block back into the torsen after swaping to 4.56 gears it will get hung up on the ring gear because the 4.10, 4.30 & 4.56 ring gears are thicker than 2.73, 3.08, 3.23, 3.42, 3.55, 3.73 & 3.90's
Just look at where the interferance is and grind that much material off the thrust block, its not much, just like 0.125 x 45 chamfer, maybe even less.
SLP sells some stupid kit for like $200 but its a rip
Old 07-31-2008, 03:51 PM
Is there any grinding on the actual carrier or just the the thrust block?
Old 07-31-2008, 04:53 PM
alamantia's Avatar
just the block
Old 07-31-2008, 08:42 PM
cool 4.56 gears ordered i found a place that had motive gears for just 155 bucks for stock 10 bolt 7.5"
Old 08-01-2008, 08:54 AM
FirstYrLS1Z's Avatar
this is what I had to do for replacing my OEM 3.23s' w/Auburn to Richmond 4.56s' on a Eaton LSD carrier.
Old 08-30-2008, 03:45 AM
14SecV6's Avatar
does grinding the tooth down create any extra gear whine? or is it alright since its out of the contact patch?
Old 08-31-2008, 09:53 AM
They were put in in sept.of 07.Been to the strip a few times,driven to florida and back from ohio(yeah,4.56s' for a 2200 mile trip) and everythings been fine.
