rearend dilemma, need some advice
Ok heres the dilemma. I found out when I went to get my gears installed that My carrier has a crack in it. The gear install is $280 and new carrier is ????? . Now the guy doing the gear install has a fresh rebuilt 10 bolt with 3.42's sitting at his house that he wants $600 for. But its a 3 channel and I have a 4 channel. I would have to reuse the axles from my 4 channel BUT!! of course, one the axle's in my rearend is going bad so I would need to buy a new or used one. Or I can buy a used rear for $350 at a local shop. However, I dont know the history of the used rear. What should I do??
and buying a 12 bolt isnt a option at this point.
Here are the Moser replacement axles for the 10 bolt. http://www.exoticperformanceplus.com...html?item=1341
Either way you go, you're going to have some serious change in a 10 bolt that eventually is bound to break on you. I'd find a used 12 bolt or 9 inch before I went with another 10 bolt. Bob
