Picking a good gear ratio?
I have a 94 LT1 6-speed car with heads cam and sray, I had a stock 10 bolt and broke it. I found a sweet deal on a moser 12 bolt. It had a set of 4:56 gears in it. My problem is threw a 1/4 mile im running out of gear and having to shift into 5th gear. Any suggestions on a good ratio would be great.
I am currently running a 26" DR, but will probably buy new 26.5" DR. Im turning around 6400rpm and falling probably 450- 500 ft. of the line in fourth. What do you guys think? Jaws if you carry anything for a moser 12 bolt i would be interested.
depends how high you are revving, stock cam or bigger cam? there is a calculator.. and if you know what speed you are trapping at use the calculator and see how tall a tire ure gonna run, etc.. and what ure 5th gear is... probably .74, but IDK about LT1 T56s...
