help changing rear axle
Old 08-20-2008, 02:02 PM
nightmare23's Avatar
Default help changing rear axle
well i got the part now i just need to change it...if anyone can help please reply or pm me
Old 08-20-2008, 02:15 PM
anyone?
Old 08-20-2008, 02:30 PM
alamantia's Avatar
the axle shaft or the whole axle?
Old 08-20-2008, 02:42 PM
Jawsgear's Avatar
- Put the car on jack stands
- Pull the differntial cover and drain oil
- Remove the wheel
- Remove the caliper
- Remove the rotor
- Remove the 5/16" cross pin bolt
- Remove the cross pin shaft or paddle
- Push axle inwards from the flange so the c/clip will drop
- Remove c/clip
- Slide Axle out
- Reassemble in reverse order
Note: Be sure to use loctite on cross pin bolt threads after you have cleaned with brake cleaner.
Jeff
Old 08-20-2008, 04:35 PM
axle shaft.... what is the cross pin shaft..sorry im not to familiar.....i opened and drained romoved a bolt ...just dont know how to get to the c clip
Old 08-20-2008, 04:42 PM
SIC LSX's Avatar
C-clip
-Remove the 5/16" cross pin bolt in center section
- Remove/pull out the cross pin shaft or paddle
- Remove c/clip
- Slide Axle out
Old 08-20-2008, 06:27 PM
got it....thanks alot guys.... ...
Old 08-20-2008, 07:15 PM
alamantia's Avatar
if its a 4 channel you will have to remove the speed sensor to push the axle in far enough for the c-clip to come out
