Gear and stall recomendations
I have a sponsor that is going to set me up with a moser 9" that I will be installing over the winter, at the same time I am going to put a bigger stall in, I figure a 3500~. The car is almost only ran at the track but does see very occasional street use just for fun, driveability is not an issue though. He knows my setup and I'm sure he has his own recommendations of what gears I should use but I'm just curious about other peoples suggestions.
Now that depends... is this a nitrous motor your putting together. Based on that cam I'd guess that you'd likely be spraying a big shot on this car. Nitrous cars don't need alot of converter, but you need a GOOD converter.
So is it a nitrous car?
