Looking at getting a ford 9 inch
How much longer or shorter in the ford 9 inch than (strange or moser) than the stock 10 bolt?? This is very important because i am running 325's and i can barely get a finger in between the tire and the lower control arm. thanks
The Moser nine inch will be in the same location as the 10 bolt, it is designed to replace the 10 bolt rear. Same length, etc. You can also order a Moser rear shorter or wider than stock for no extra charge. Bob
