surface rust/corosion on gears
I am going to be cleaning up a set of gears and am wondering what is the best way to do so? Steel Wool or Sand Paper? The gears should still be usable without a problem correct?
I bought the Richmond gears used with about 3k miles on them and the previous owner had just a bit of corrosion where it looks like the bearing is going to be pressed onto the pinion.
Thanks!
-Karl
Thanks!
-Karl
