9" yoke question
Old 09-20-2008, 11:31 PM
JASON 77's Avatar
Default 9" yoke question
bought a differential off here, it has a stock yoke on it. want to buy a billet yoke for the bigger u joint. my question is when i remove the stock one, does the other one bolt right back up or do i have to adjust the pinion for the new billet piece? do not know if it needs reshimmed or do they have a crush sleeve?
Old 09-20-2008, 11:46 PM
Grn4fbody's Avatar
Well you should have a new crush sleeve put in it,but i'm sure if you dont TQ the **** out of it you'd be fine.
Old 09-20-2008, 11:50 PM
JASON 77's Avatar
i have no problem with putting in a new sleeve. did not know for sure if it took a crush sleeve or if it was shimmed instead of the sleeve.
Old 09-21-2008, 12:11 AM
Grn4fbody's Avatar
Should be both,your pinion support will...or SHOULD have shims under it.
