Clunk sound when kicking passenger rear tire...
Old 09-25-2008, 02:15 PM
FCar2000TA's Avatar
Default Clunk sound when kicking passenger rear tire...
My buddy just bought a 99 Camaro, and when you kinda kick the passenger rear tire, there is a clunking sound. Also makes the sound when going over bumps and when pushing the body side to side from the rear. Loose nut on the suspension?? I am thinking the sway bar mount or the lower shock mount.
Old 09-26-2008, 04:33 PM
LS1>girlfriend's Avatar
jack up the rear, then push and pull on either of the rear wheels and tell us if you hear the same sound. if you do, its the space machined into the rear to allow you to remove the c-clips from the diff and is totally normal.
if its not the same sound, check the rear end for loose nuts and bolts and report back.
Old 09-26-2008, 04:35 PM
FCar2000TA's Avatar
it only makes the sound on one side, and it definitely does not sound normal. Neither of my TAs did this.
it's a V6 Camaro though, so the rearend is different
Old 09-26-2008, 05:41 PM
i would lay under the rear for a bit and see if you notice anything.
the only difference between an ls1 and v6 rear is the open diff in the v6.
Old 09-29-2008, 04:41 PM
crazylane's Avatar
Check your backing plate bolts.. I had two sheared off, and two that were loose, all on one side.. If thats not it, then check your bearings? Does it make any crazy sounds going down the road??
Old 09-29-2008, 04:45 PM
turbowhistle86's Avatar
mine had the same problem and it was the Panhard Rod....the adjustable portion had a loose jamnut. Also check LCA bolts and lower shock mount.
Quick Reply: Clunk sound when kicking passenger rear tire...
