stock length driveshaft with 12 bolt?
Old 09-29-2008, 08:47 PM
red6speedss's Avatar
Default stock length driveshaft with 12 bolt?
Will a stock length drive shaft work in a 98 ss with a 12 bolt and 1350 yoke?
Old 09-29-2008, 09:12 PM
Speed Kills's Avatar
With the 1350 yoke, you will need a shorter driveshaft. I have a like new Spohn Top Gun driveshaft for M6/12 bolt if you'd be interested, PM me and I'll make you a good deal on it.
Either way, hope that helps!
Old 09-30-2008, 05:40 AM
EPP
EPP's Avatar
Question
?? The stock driveshaft works with the 12 bolt. The conversion u joint does not extend the length of the driveshaft any. Bob
Old 09-30-2008, 05:15 PM
LS1-STANG's Avatar
Yes the stocker will work with the correct U-joint
Old 09-30-2008, 07:50 PM
LS1>girlfriend's Avatar
wrong, the stock driveshaft will work with a 1350 yoke and 1310/1350 u-joint.
i, among many others have done it.
Old 09-30-2008, 09:17 PM
ok I tried a stock driveshaft and it wouldnt fit. too long
Old 09-30-2008, 09:22 PM
SS1875's Avatar
I used a stock length LPE 3.5" DS with conversion u-joint on my Moser 12 bolt when I had it.....fit fine for me.(M6 Car).
Old 09-30-2008, 09:40 PM
INMY01TA's Avatar
Stocker fit fine with my Strange 12 bolt/1350.
Old 10-01-2008, 04:46 AM
EPP
EPP's Avatar
Question
Did you have the car up on jacks with the rear hanging down?
Old 10-01-2008, 05:52 PM
Black 99 Bird's Avatar
So you are running a shorter shaft now??? I hope not, the stock one is fine.
Old 10-02-2008, 07:31 AM
SS1875's Avatar
With the car on jack stands , put a jack under the rearend and jack it up(as if car was on the ground with load on it). Measure from the center of the rear yoke to the back of the transmission. There is no way a stock shaft would be too long for your application.
Old 11-03-2008, 08:36 PM
gapp94vert's Avatar
When I bought my moser 12 bolt I put it in on a lift and it was hard to get the driveshaft in. Is this normal I practically had to pry in my driveshaft. It sits really tight against the back of the trans.
Old 11-04-2008, 03:43 AM
EPP
EPP's Avatar
Thumbs up
Yes, on a lift it will be difficult. The 12 bolt driveshaft length is the same as the 10 bolt's. Bob
Quick Reply: stock length driveshaft with 12 bolt?
