Bang in drivers rear when hitting 2nd hard
Old 09-30-2008, 01:37 AM
mvvette97's Avatar
Default Bang in drivers rear when hitting 2nd hard
I can't seem to find anything wrong. I have a set of bolton relocation brackets and weld on subframe connectors. I have ruled out the exhaust and all the bushing seem tight. I jacked it up and can't find anything loose. It doesn't do it all the time mostly on a good surface when it seems to get traction. Anybody else ever have this?
Old 09-30-2008, 09:41 PM
SS1875's Avatar
I would say the TA if your for sure it's not the exhaust. My Spohn TA used to making a Popping noise and feel like it would hit around that area under certain conditions. We had to clearance it away from the frame.
Old 09-30-2008, 10:25 PM
mvvette97's Avatar
Are you talking about the large arm from the tranny to the rearend?
Old 09-30-2008, 11:24 PM
SS1875's Avatar
That would be the one.....also found that the plate that mounts the TA to the rearend (when I had my 12 bolt) was cracked through one of the bolt holes....honestly it could be anything....noises are hard to track down especially when most of this stuff is connected in someway or another. Did you check the PHB/Shock bolts etc.??
Old 09-30-2008, 11:28 PM
mvvette97's Avatar
where did you have to clearance it at? Mine is stock so I wouldn't think I would have that problem but maybe I do.
Old 09-30-2008, 11:33 PM
SS1875's Avatar
Probably not the culprit then.....mine was with the aftermarket TA and 12 bolt. But it was in the tunnel area near the driver rear wheel.
Old 09-30-2008, 11:36 PM
SS1875's Avatar
Did you check your trans mount/ u-joint?? Where exactly does it feel like it hits??
Old 09-30-2008, 11:41 PM
mvvette97's Avatar
yea everything feels fine. It doesn't really feel like a hit or anything but just a loud bang at the drivers rear wheel. I even had the rearend apart and pulled the axle to check the wheel bearing and it was fine also. I have the relacation brackets for the control arms and is it even possible to lift too much and top out a shock? Sounds like a crazy thought but everything else seems fine
Old 09-30-2008, 11:48 PM
SS1875's Avatar
Interesting.....any rub marks in the wheel well like a tire making contact, brakes are all tight ? Broken shock?? I'm running out of ideas here
Old 09-30-2008, 11:51 PM
mvvette97's Avatar
I didn't see any marks on the tire and the brakes are tight. I thought the shocks were ok but I never really looked at them. I'll have to check them out.
Old 09-30-2008, 11:56 PM
SS1875's Avatar
Good luck I hope you find it....reminds me of the Vibration I was chasing not so long ago... changed anything and everything only to find out it was my ASP underdrive pulley wobbling (had 2 that did this).
Old 10-01-2008, 12:00 AM
sic2001's Avatar
My TA was banging on the floor in front of the pumpkin when it was just lowered. I bet if you look under there you'll see a clean place where it rubs and bangs under load.
Old 10-01-2008, 12:05 AM
SS1875's Avatar
Around the rear seat back brace??
Old 10-01-2008, 12:07 AM
sic2001's Avatar
exaclty
Old 11-15-2008, 03:05 AM
MeangreenHD's Avatar
if you have a spohn torque arm, i would check the driveshaft loop, i am still having issues of the driveshaft not centered in the loop and it catches the ds weight when the car hits a bump and travels higher than stock ride height. look for shiny marks on your ds around that area. not saying it is what yours is doing but it sure is a horrible noise and thats where mine was coming from.
Old 11-15-2008, 03:07 AM
lemons12's Avatar
when you shift does your actual shift ****/arm whatever have play in it.. like move around?
if so tranny mount
Old 11-15-2008, 03:33 AM
jsteele90's Avatar
check your exhaust at the muffler see how loose it is
Old 11-15-2008, 03:40 AM
doaberetta's Avatar
Check your sub frame connectors. Maybe the 1st to 2nd is torquing the car enough to shift them enough to make a peep... Look at the bolts and see if they slid in the mount. (if the hole for the bolt has some room to slide.)
