Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
Gforce engineering irs fab 9
Old 08-20-2010, 09:24 PM
Gforce Engineering's Avatar
Default Gforce engineering irs fab 9
Hey guys,
Thought I would give you all a sneak peak at our fabbed IRS 9" housing were developing for the Camaro.
This is the base housing that we will use for several platforms. We have tooling that will allow us to jig locate brackets to bolt the fabbed IRS 9" into the Camaro, G8, CTS-V and the GTO.
The rear will also come with our 300m axles and choice of aluminum or carbon fiber driveshaft .
The housing was all designed in 3-D CAD and fit together perfect the first time
Thanks
Chris
Old 08-20-2010, 10:20 PM
blackonblacksls's Avatar
I like that..
Old 08-22-2010, 11:49 AM
edmanet's Avatar
Now you come up with this......after I get a truetrac and chromoly axles.
Old 08-22-2010, 12:05 PM
Hey, what can I say
You should check out the progress on the CTS-V kit in the caddie section.
Thanks
Chris
Old 08-22-2010, 12:07 PM
Devilish34's Avatar
nice......$$$$$?
Old 08-22-2010, 01:18 PM
Egg1456's Avatar
If only someone would come up with an irs system for 4th gens
Old 08-22-2010, 05:30 PM
DietCoke's Avatar
Very nice looking piece
Old 08-24-2010, 10:56 AM
FLP
LS1TECH Sponsor
FLP's Avatar
Once we get the 427 in our car I will probably be calling you for one of these... :-)
Old 08-25-2010, 10:31 PM
Sounds great
Just give me a call when your ready. I've got several shop cars getting this rear. A couple will be in PRI and several in SEMA.
Thanks
Chris
Old 08-27-2010, 09:07 PM
Never Satisfied's Avatar
Hey Chris, I think I just fragged my Richmond geared stock unit tonight. Just had them installed on the 6th of August. I guess that's what I get for thinking GM could put a stout rear in a Camaro. Didn't even get it to the track yet.
Can you PM or better yet email me the details along with cost for this setup? My email is red306bullet@verizon.net
Thanks,
Old 08-28-2010, 05:39 PM
Thanks,
Will do, I'll shoot you an email.
Give me a call Monday and I'll talk it over with you.
Thanks
Chris
Old 08-28-2010, 05:41 PM
Just got the pricing figured out.
pricing.
$5562.
Here is what you get.
  • Fabricated bolt in housing
  • Powder coated to what ever color you want (Black is standard)
  • BMR heavy duty bushings.
  • Strange Engineering Pro Iron center section w/gears and Truetrac installed and set up
  • 3.5" Aluminum Driveshaft (Add $400. for Carbon Fiber)
  • 300m Axles and stubs
The best part about the 9" is you'll be able to change out gears for dirt cheap. Alot of guys that run 9" rears will have 2 drop out pumpkins, one with say 4.56 gears for the track and one with 3.xx gears for the highway. Since the 9" is a drop out style rear, all you have to do is swap the pumpkins out and your done, no setting up the gears or anything.
For those of you that dont know anything about a 9", you set the pumpkin (the center section part) up on a bench and then you just bolt it in the housing. Very easy to work on.
Thanks
Chris
Old 08-30-2010, 06:24 PM
speedster94's Avatar
pricing.
$5562.
Thanks
Chris
Awesome Chris. As soon as you get the 9" done for the Camaro, please yell. Plus I'd like the Outlaw Axles if that is the way to go. The only other thing is a Truetrac versus a locker. You know better than I do.
Old 08-30-2010, 06:40 PM
Sure thing Bruce. We're installing our first 9" IRS into a bad *** CTS-V in a couple weeks.
When I get one ready I'll send it your way. And yes, we can do the Outlaw axles but you'll have to modify the control arms a bit.
Thanks
Chris
Old 08-31-2010, 06:53 AM
Actually if you go with 35 spline, a Moser Wavetrac would be a unit I'd love to try out.
Old 08-31-2010, 06:57 AM
33 spline is standard and 35 is an option with our 9" and you cant go wrong with the wave trac and it's lifetime warranty
Old 09-04-2010, 08:09 AM
Updates ? Thanks Chris.
Old 09-04-2010, 09:14 AM
Still waiting for our cnc machines to get up and going. Waiting on electricians and inspections take for ever..
This coming week should be a good week
Old 09-07-2010, 08:55 PM
Devilish34's Avatar
****!! I forgot about this.....
Old 09-09-2010, 08:36 PM
LSXtv.com is going to do a full write up on the first kit going into a tricked out cts-v in a about a week.
We've been cranking out parts on the cnc mill the last couple days so production should start here real soon.
Thanks
Chris
Quick Reply: Gforce engineering irs fab 9
