Driveshaft Shop announces an exclusive 33 spline Wavetrac for the 9" kits - LS1TECH
Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
Thread Tools Search this Thread
Old 10-11-2011, 10:48 AM   #1
Driveshaft Shop's Avatar
Default Driveshaft Shop announces an exclusive 33 spline Wavetrac for the 9" kits
Dss is proud to announce its exclusive deal with Wavetrac for the 33 spline 9" Ford units, this is the same 33 spline the outer CV on the Camaro has and will compliment the 9" kits. we only went with 33 spline as the 31 and the 35 spline unit is an exclusive with Moser and we wanted to be able to sell the diff with our Strange case and other internals. This Diff is in stock and we will have the stubs done shortly. This also allows us to make a new "PRO" version of the 9" using a outer we are developing with a 33 spline internal so the entire axle will have 33 splines all the way thru. so if your serious about having the best 9" kit that will now include the strongest axles that are second to none along with a Wavetrac diff its here now at DSS. (just in case an Eaton or Locker isn't up to the job)
Driveshaft Shop is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Driveshaft Shop 9" conversion !!!!! Driveshaft Shop Gen 5 Camaro Drivetrain Tech 14 07-17-2015 07:15 PM
Driveshaft Shop changes all it GTO parts to 300M Driveshaft Shop Pontiac GTO 2004-2006 5 04-03-2014 10:46 AM
Carbon Fiber Driveshafts from Driveshaft Shop Driveshaft Shop Gears & Axles 8 03-26-2014 01:14 PM
Holden Commodore VS Axles from DSS Driveshaft Shop Holden Performance 0 11-08-2011 06:21 PM
Driveshaft Shop Carbon Fiber shafts Explained Driveshaft Shop Pontiac GTO 2004-2006 9 04-22-2011 03:00 PM
Tags
2010, 33, 9, camaro, differential, driveshaft, ford, gen, internal, locker, ls1tech, spline, strange, wavetrac, wavetrack
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
