Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
2010 - 2015 Camaro SS 8.6 Carrier Bearings and Races Part Number
Old 09-02-2016, 02:23 PM
Camaros-n-Chevelles's Avatar
Default 2010 - 2015 Camaro SS 8.6 Carrier Bearings and Races Part Number
Hi Guys,
I am upgrading the Posi Unit in my 2012 Camaro SS and would like to change the Carrier Bearings and Races while the Posi is out.
http://www.ebay.com/itm/161069391388...84.m1555.l2649
Does anybody have the Timken Set Number or individual Part Numbers?
Any help is greatly appreciated.
Thank You.
Old 09-03-2016, 08:58 AM
I found the carrier bearings and races.
http://www.ebay.com/itm/Chevrolet-Ca...VWSy-M&vxp=mtr
Now I need to find the Timken cross reference number.
Thank You.
Old 09-05-2016, 05:19 PM
motion427's Avatar
Not sure if Timken makes them. The bearing kits that we get for the Camaro think it uses Koyo bearings for the carrier bearings.I can get the Koyo numbers if that helps ?
Old 09-05-2016, 08:40 PM
Hi,
Finding the part numbers would be great.
Thank You for your help. I really appreciate it.
Old 09-06-2016, 02:03 PM
motion427's Avatar
Actually I received the Timken numbers.
LM603012
LM603049
Maybe you should look at a shim kit aswell to adjust the backlash and preload on the carrier bearings. Yukon ha a kit that gives you the carrier bearings and shims.Think the part number is 57010.
On another note, I think these are the same carrier bearings that are used in the late model 8.6" GM truck and the old GM12 bolt.
Old 09-09-2016, 08:28 PM
That is awesome.
Thank You very much for researching the Timken Part Numbers.
Quick Reply: 2010 - 2015 Camaro SS 8.6 Carrier Bearings and Races Part Number
