BBK Long Tube V6 Headers..?
Old 02-15-2010, 07:47 PM
2wd1500Crew's Avatar
Default BBK Long Tube V6 Headers..?
Has anyone purchased the BBK headers for the V6 yet.? I want to know if they throw a code with the high flow single cat verses the stock dual cat.? I would not to put out 800. bucks to get get an engine fault code..
Old 02-15-2010, 09:56 PM
someday's Avatar
how is it a single cat? the stock exhaust is true dual like the V8's... headers should be the same as the V8's...
Old 03-01-2010, 08:09 PM
Default SomeDay
Look at the factory exhaust removed from the vehicle and then the replacement. Is that just a factoy resonator inline that is dismissed from the BBK kit.?
http://www.phastekperformance.com/20...headers-v6.htm
Old 03-01-2010, 10:56 PM
someday's Avatar
just like the V8's, it has 4 cats stock, 2 per bank, the aftermarket uses just 1 per bank... the improvement above 5000 is incredible... can't believe how restrictive the factory stuff is above 5000...
Old 03-18-2010, 01:35 AM
Default One Cat per side, thought so..
Yes, I thought I saw that correctly. My wife would like the exhaust for her car but I was concerned about fault codes..
