Radio Removal
Old 03-18-2010, 09:30 PM
bowtieboy_572's Avatar
Default Radio Removal
has anyone tried to pull the radio out? if so pics or steps?
Old 03-19-2010, 12:01 AM
ThunderZ28's Avatar
If your trying to put an aftermarket radio.. not going to happen...
there isn't anything out there that's cost effective..
Going to cost you a butt load..
the radio/AC controls/lock/unlock button/hazard lights, are all one piece, as well as the radio is pretty much the brains for most of the other functions in the car..
Which really sucks cause I have a perfectly good Sony receiver I would love to put in the car...
One guy I have seen has done it, but there is a BUNCH of custom modifications that where done to get everything to work..
If your just wanting to pull it out..
there is a write up on Camaro5 somewhere..I believe
Old 03-19-2010, 12:03 AM
Luckymex_dallas's Avatar
i was gon ask the same question
i dont see why i would ever change it unless i was fgoing to dramatically change the whole dash and controls around...
..the only downside i though about this car..
in the vettes you can at least change the radio..
..not too bad of a problem since the sound system in the 2ssrs sounds great as it is. may just add a small sub thats all,
till then im enjoyin the XM
Old 03-19-2010, 12:15 AM
ThunderZ28's Avatar
this is what I did..
added a 1000Watt amp, and 2 12inch Subs..
Hits hard as hell, and the Boston sounds good with it.
Old 03-20-2010, 09:23 PM
that is what a friend of mine wants to do is add a sub, are there preouts for the amp on the factory unit?
Old 03-20-2010, 10:05 PM
ThunderZ28's Avatar
you will have to tap the wires before the amp.
I will see if I can find the hook ups I used..
I will have to wait for the car to get back from the shop, before I can do that though unless someone else has it...
Old 03-20-2010, 10:31 PM
95TAJade's Avatar
Metra makes a replacement dash kit which includes an adapter harness. Retains all features of the factory dash piece. Allows for the installation of a single or double din head unit. part # 99-3010S
Old 03-20-2010, 10:35 PM
95TAJade's Avatar
btw that kit is probably gonna run around $200.00 fwiw.
Quick Reply: Radio Removal
