anyone have the raptor shift light
Old 03-21-2010, 01:31 AM
treedoc2000's Avatar
Default anyone have the raptor shift light
Im trying to find where to run the white wire for the dual mode raptor shift light?? Anyone have this installed?? Thanks
Old 03-21-2010, 01:28 PM
Nobody??????
Old 03-21-2010, 08:43 PM
ss1129's Avatar
You try calling them and asking? Id bet they get that a lot.
Old 03-21-2010, 10:36 PM
Guess youre right. Ill give them a call
Old 03-22-2010, 08:41 AM
jamnut's Avatar
I'll be going to the dealership for a pin out schematic for the 5th gens on Monday/Tuesday. I'm running one on my 4th gen & have 1 to hook up to my 5th gen.
Old 03-22-2010, 04:09 PM
ThunderZ28's Avatar
I did a write up on camaro5.
It's in the how too section. I am not at my computer, I'm on my Droid. But if you go over there and search threads by ThunderSS you will see the Raptor install.(pin locations, and pictures) If I get back on here, and you still havnt found it I will find it and post it up. It will be late tonight before I can do that.
Old 03-22-2010, 11:10 PM
Hey Jamnut, If you find anything good please hollar back.
Old 03-22-2010, 11:14 PM
Yeah, I have read your erite-up and although a very nice article, my x1 at the pcm does not have the gray wire with blk stripe-doesnt even have a wire in the spot that your diagram shows. I called raptor today and they are sending me an amplifier. They said on this car , I will need to tap the coil wire with this amplifier??? Anyway Im gonna give it a try when it arrives. Nothing is ever easy
Old 03-23-2010, 05:20 AM
ThunderZ28's Avatar
not trying to sound like an ***,
But where you looking at the grey one?
Just verifying..
I had the same problem at first and figured out I was looking at it wrong.
Wish you where closer to houston.. I would help you install it..
The Amplifier should help make it a bit easier..
when I had installed mine Raptor hadnt fixed that problem yet..
Old 03-23-2010, 01:40 PM
Just verifying..
I was instructed to pull both the X1 and the X2 wire harness plugs off the PCM(located in the engine compartment). Instructions say look at the X1 plug ( black one ) and locate the (i think 71 pin??) gray wire with a black stripe and showed pictures of where this wire was exactly. My plug has a empty spot where they showed this wire and I only found solid gray wire in the harness no stripes? Is yours a A6 also? and where did you run your wire to?? Sounds like the amp deal is gonna be a pain also Thanks
Old 03-23-2010, 09:07 PM
ThunderZ28's Avatar
This is what you should be looking at.. whether it's an L99 or LS3, they are both the same..
White wire goes to X1(Black Connector)/Pin 71, and the Green Wire goes to X2(Grey Connector)/ Pin 20.
I am waiting for raptor to send the Amplifier, and see what needs to be changed from there.
Old 03-23-2010, 09:46 PM
Hmmm Dont have it! Mine has the funky large blk wire that kinda goes into the barrel but I do not have these wire that u have??
Old 03-23-2010, 09:48 PM
Matter of fact The two purple wires you show at the end of the connector, I dont have those either??
Old 03-24-2010, 06:09 AM
ThunderZ28's Avatar
you have a camaro, right?
lol
ThunderZ28's Avatar
can you take a picture of the connector???
Old 03-24-2010, 08:33 AM
LOL yeah that was my first thought. But yes 2010 2SS RS Ive had a few others message me and say that they have the same problem?? Guess Ill wait to see what the "amplifier" does.
Quick Reply: anyone have the raptor shift light
