Need some help with a fuel pump. - LS1TECH
Thread Tools Search this Thread
Old 10-30-2010, 08:02 PM   #1
Estes's Avatar
Default Need some help with a fuel pump.
Need to know what after market fuel pump to run on the 2010 Camaro. I've heard of people doing the boost a pump with success, but am checking out all avenues. I've tried doing searches and nothing specific comes up. Any ideas?? I do most of my shopping online since I'm in Africa most of the time. I'd hate to get home and be ready to go and then a fuel pump wont fit or something. BTW, I'm putting in a 76mm Turbo. That's the reason for the Fuel upgrade. Should be going with 60lb. injectors as well. Any help would be appreciated....thanks.
Estes is offline   Reply With Quote
Old 11-02-2010, 04:14 PM   #2
silver2010's Avatar
The boost a pump is good up to about 550 rwhp. After that you will need a duel pump that fits right in your tank as a replacement like from fastlane. These are good up to 800 rwhp. After that you will need a custom system.
silver2010 is offline   Reply With Quote
Old 11-03-2010, 04:38 AM   #3
Estes's Avatar
I've seen the Fastlane unit...very nice. I'm wondering if I can replace the existing one with a more rowdy unit and keep my stock housing. Yes, I would have to re hose it and change it out on my own, but this is not an issue. I've been told the Walbro 255 is a good one to use. Any thoughts on this?
Old 11-19-2010, 08:01 PM   #4
LS1TECH Sponsor
Lonnies Performance's Avatar
I offer a drop in, dual intank pump kit. They have proven very reliable & easy to install.
There is no easy way to add a Walbro 255 pump as the factory pump is pulse width modulated. This will not work well with a standard pump.
The fuel transfer function is rather complex & does not typically function if the bucket is modified. Also due to the effort required to drop the tank, you will only want to do it once.
I also have a triple setup for power ranges from 800-1500rwhp.
If I can interest you in kit, please give me a call.
Lonnies Performance is offline   Reply With Quote
Tags
2010, camaro, change, fuel, gen, ls1, modulator, pulse, pump, tech, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
