Pheonix Gold iAMP-GM1 for you 2010 and 2011 Camaro owners!
Closed ex-Sponsor Account
iAMP-GM1
Now plug and play upgrade for your 2010 and 2011 Camaro!
This is an awesome package to increase the performance of your factory system. Simple install takes an hour or less
complete instructions available
CALL FOR PRICE
608 568 3011
iAMP-GM1
Category:OEM INTEGRATION KIT
Series:I SERIES
Description:OEM Integration Amplifier & Subwoofer Kit for 2010/2011 Chevrolet Camaro
The i-Series is the first aftermarket mobile amplifier with full databus awareness and integration, this means it can replace the factory amplifier in a nearly plug n’ play installation. Installing an amplifier into a newer car can be a painful experience of splicing into a maze of wires or using buggy black boxes that will disable many key OEM features and functions of the vehicle. Installing an i-Series amplifier is easy, simply remove the stock amplifier, then plug in the i-Series amplifier using the provided wiring harnesses. There are no wires to cut, no fishing for obscure wires and no additional band aids to wire up. The amplifier fully retains all the OEM functions such as steering wheel controls, head unit functionality, Bluetooth, OnStar, chime function, etc. This makes for a predictable and painless installation that is completely reversible when the lease is up or the vehicle is sold.
Key Features
USER MANUAL
http://www.phoenixgold.com/images/pd...UserManual.pdf
INSTALLATION MANUAL
http://www.phoenixgold.com/images/pd...tallManual.pdf
CALL FOR PRICE
608 568 3011
iAMP-GM1
Series:I SERIES
Key Features
- All-in-one, complete high-power car audio upgrade solution
- 1 hour, quick and painless installation
- AMPLIFIER (i800.6)
- 800 Watts, 6 Channels
- First fully integrated aftermarket mobile audio amplifier with full data-bus awareness and integration
- Created in collaboration with Pacific Accessory Corporation (PAC) OEM integration experts
- Easy Plug and Play OEM installation with provided signal and power wiring harnesses
- Fully retains all OEM/stock functions such as steering wheel controls, Headunit, Onstar, Bluetooth, etc.
- Digital Signal Processing System for proper OEM signal integration, crossover, time alignment and equalization for factory speakers
- Touch Panel DSP remote control allows adjustment of sub-level, DSP presets, settings, etc.
- 3.5mm Auxiliary Input for easy integration of portable music devices
- Subwoofer Pre-Amp Output for easy addition of an even larger subwoofer amplifier
- Remote turn-on output for triggering additional aftermarket amplifiers
- SUBWOOFER
- 10” High Power Subwoofer
- High Efficiency Vented Enclosure
- Integrated Amplifier Rack
- POWER RATING
Front/Rear: 60 Watts x 4 Channel / 4 Ohm - POWER RATING
Center: 25 watts x 1 Channel / 4 Ohm - POWER RATING
Sub: 320 watts x 1 Channel / 2 Ohm - POWER RATING
Sub Low Pass Range 30Hz to 300Hz - LOW PASS SLOPE
24dB/Octave - HIGH PASS RANGE
40Hz to 400Hz - HIGH PASS SLOPE
12dB/Octave - BASS BOOST
0 to +18dB - POWER TERMINAL
4GA - FREQ RESPONSE
20Hz to 20kHz (+/- 1dB) - SIGNAL TO NOISE RATIO
Greater than 100dB - HARMONIC DISTORTION
Less than .01% - EFFICIENCY
50% - DAMPING FACTOR
Greater than 200 - HEATSINK THERMAL MASS
9.5 grams per mm
USER MANUAL
INSTALLATION MANUAL
If this thing is $1600 list, I'm hoping a vendor can save us a BUNCH of money.
Does anyone know what speaker is in it?
Has anyone actually used it? I've got an older PG amp in my Mustang and it's been a workhorse of near indestructibility. I'd love to pick up another one.
